Handbrake warning light
Handbrake ON light on instrument panel gone very dim. Occasionally will flicker and comes on normal for a very short period. Handbrake switch changed to no effect. Hope its not instrument cluster. Has anyone had a similiar prob?. Car is a 52 plate comfort estate 1.9tdi
Have you checked the brake fluid?
If all OK, It could be a failing LED!
check brake fluid. Are there any beeping sounds? Turned out to be leaking brake fluid on my pd100.
Yes no problem with fluid, I have had in the past two months an ABS warning with a loud buzzer, this was cured by stopping waiting 10 secs and restarting. Brakes etc serviced regularly and ABS works OK
