help! connects 2 ipod connection.
hi all. Has anybody got any information on the best way to route the ipod cable from the back of the stereo without to much trouble and preferably not too ugly.
cheers tom
Hi and welcome to the site. :)
If you remove the glovebox (literally 6 botls), then you can pull the wire through from the back of the headunit. Then the wire can go through the little tab thing that's usually used for holding the glovebox false floor in the up right position. They say a picture says a thousand words:
Although this is useless if you need to access the iPod to control it I guess (not sure if you will).
Edited by TriggerFish
I've fitted these into both mine and my mrs' vRS's. I went for the option of running the cable down the centre console and out into the little tray in front of the ashtray. I've then fitted an ipod / phone holder i got from Halfrauds into each car that is attached to the passenger side of the transmission tunnel so as to be able to connect the ipod/iPhone and still be able to control it etc... When not in use the cable just lays very un-noticeably in the little tray.
There's no removing of trim and no cutting of holes required for this one so it's easy to remove and leave no damage when it comes to selling the car on.
I can't get any pics at the mo but can post some up later if you like?
Dave.
Edited by WaveyDavey
Just noticed from your profile you have a VW Golf and you have also asked about retro fitting cruise control to a Roomster. (No mention of a mk1 fabia). Just wanted to make sure the connects2 was being fitted in a mk1 Fabia as if not you've posted this in the wrong forum and any suggestions won't be much use to you. :thumbup:
Dave.
Dave.
yes i now have a mk1 fabia aswell so need to make it ipod compatible. if you could put up some pictures that would be very useful.
Ta, Tom
Ta, Tom
No probs matey.... I'm out in the car tomorrow so i'll post some up for you tomorrow evening time. :thumbup:
Dave.
Here ya go.......
The supplied cable is just long enough to go straight down below the HU and there's a little gap between the trim above the tray in front of the ashtray so as to feed the cable through. When not in use it sits neatly in the tray then when i want to connect one of our iPhones it reaches just nicely to the phone holder on the leftside.
Hope this helps
Dave.
Here ya go.......
Hope this helps
Dave.
very good pics cheers. this worked a treat. many thanks Tom
No probs. Glad it was of use to you and that you got it all sorted in the end. :thumbup:
Dave.
my connects 2 sounds like I have a mini turbo every time i accelerate... is there a way to stop that annoying noise? :S
is it really £50 for this kit :o
They were £30 when i got ours a couple of years ago.
Dave.
1. check that it's properly grounded.
2. fit a "big" capacity to on the live feed, but i've never heard of that being necessary. probably (1).
  • 5 months later...
do these connects 2 work on a 56 plate?
Yes Markbob :yes: :)
Linky
Edited by bartsimmo
Linky
cracking :thumbup:
Hi Everyone,
Sorry to sound a bit of a noob .. I have just bought a 2006 Skoda Fabia VRS and want to get ipod connectivity and noticed this post on the forum.
Is anyone able to send a link to me for the Connect2 ipod system and also is it easy to fit?
1) Does it just connect into the back of the symphony cd unit?
2) Is it just one wire?
Any help appreciated, many thanks
Ryan
