can autowipe be disabled?
Is there a way to disable the 3 auto-wipes that it does everytime I use the washer jet?
:S
:S
Yes, via VCDS.
Is this a car-related thread? ;)
Thats some high tech Bidet hes got :giggle:
I'd like to know VCDS coding for disabling or at least to make it once in 20 times the washer for lights. It's annoying, spends too much water, and many times with windows open driving slowly I sprayed myself with water and passing by walkers!
So would I. Also, it's the drip wipe that really bugs me. With Rain-X it isn't necessary.
I was looking at the Haynes book of lies, and wondering if disconnecting a specific pin to the wiper relay could get the same effect... ;)
...and without having to play with any software
Surely 5 minutes with VCDS is easier (&safer) than disconnecting pins/wires?
I doubt disconnection of a wire will achieve what you want as the ECU's on the car communicate via CANBUS so chances are you'll affect something else as well by messing with wiring.
shows how much I know about the electrics of modern cars :doh:
how difficult and expensive is the VCDS way?
Easy and about 220 quid.
Or free if you already have the Ross-Tech cable and software ;)
