ebay cruise control
I thought this needed vagcom to activate it?
Nowhere near as straightforward as you think i'm afraid.
1.5 to 2 hours for an expert (BigK :) ) to fit.
Also needs the VAG diag tool to re-code the ECU for cruise (not sure about Vag-Com)
Personally, i'd rather pay a pro
The RRP is NOT
Dont forget, that wiring loom is not suitable for the octy vRS as a required loom which is already fitted to some vag cars is not present. You will need to fabricate one yourself and connect this cable to the appropriate pins on the ecu direct.
