Fabia 3 odity.....
Hi,
Was going to post this in the "Ask a Tech" section but, for some reason, couldn't start a new post there.
Anyway, for some reason the temperature units on the LCD of my Fabia 3's Climatronic have, despite my not knowingly pressed a button to cause this, changed from degrees C to degrees F.....
..... but the Maxidot on the dash continues to use degrees C.....
When I left Exford (West Somerset) this afternoon the display was on degrees C so I am not sure at what point the display changed. I spoke to the service department at the dealership where I got the car but they had never heard of it changing itself. Anyone know:
- how the change might have taken place?
- how I can reverse it and make the Climatronic's LCD show degrees C again?
Thanks.
Dave
you have to be a freedom member to ask a tech do it. Its certainly worth it.
Thats a bit strange... had a look in the manual? Not tried it myself, but do either of the dials click in?
Found a solution on a passat forum but they have a different interface but similar may apply. Hold down the recirculate button and press + it said. I think that may be hold down the recirc button and turn the temp increase knob?
Edit: Looked in Fabia owners manual. Press Auto and AC at the same time to toggle between the two settings
Edited by Fatbloke
LOL, now i really hate the maxi-dot on my Fab 3!
LCD looks so much better!
Hi,
Thanks.
Dave
I think the solution is to press the auto and econ button at the same time. :sun: :sun: You will feel warmer then.
oops, :wall: :wall: soz, didn't see the previous correct post.
Edited by SlobbyK
