1.9TDI Gauges
Looking at getting to gauges for me car, turbo pressure and water temp. water temp due to the fact the standard car does not have one which confuses me.
Was needing to know if there is already a sensor there that can be used or a new sensor will need to be fitted for the water temp to work.
Any info will be useful, Cheers.
You sure there's no water/coolant temp gauge? there should be... my 1.9 tdi does, just no oil temp gauge which I personally think should be fitted to all cars
Yeah, u got a mechanical gauge like or electrical one in the mpg stuff?
Mine has nothing, would like to set one up for winter. I also have the standard dash on the sport model, do you have the maxidot or anything?
Mechanical mate, just under the tach... not sure what I have in all honesty lol
It looks like this (borrowed from DaveHarries)
Can see it just below the tach on the left
Yeah mate my rev meter and speedo do not have any gauges in them, my fuel level is in the middle as an lcd.
So does nobody one know if the thermastat sensor can be used to make an aftermarket gauge work thanks?
