The 312mm Debate
Have a look at Ross (Tech1e's) TG, and the difference is obvious!
HTH
Any link for whatever you are referring to? quite interested to see the difference now, as i assumed they used the same caliper,
Have you asked the missus the same question? :rofl:
not yet.... i will tomorrow :smirk:
312mm pictorial in the guides section, however i have to rehost the pics and edit it.
anyone know if the tt brake lines fit the fabia?
no need to fit them as the fabia ones fit fine
*cough* Lummox *cough* where is it i cannot see it?? :S
Ohhhh:
Skoda Discussion > Genral Guides
Not
Skoda Discussions» Skoda Fabia Owners» Skoda Fabia Technical
:giggle:
Ohhhh:
Not
:giggle:
Either way a search for 312mm pictorial brings it up ;)
Says nothing about the Caliper difference (piston Size)..... :wonder:
Piston size is identical 54mm iirc.
And the first picture shows the difference between the two types of caliper. I'll fix it later.
Well that is a bummer..... the only other thing i can think of apart from me being crasy, is the way the caliper floats to the carrier.....
Is the pad size different? Can't remember.
Surface area on the pad is the same as the 312, just the 312mm have more face than a 288mm obvoiusly
Pads size and thus contact area is exactly the same.
The only difference mechanically is a larger diameter disc gives more effect as it has greater leverage.
The standard calipers are made by Lucas. The golf ones are ATE, different shape caliper and the way the mount together.
Is there a chance that will make a difference?
or am i fishing for unicorns here? :giggle:
Thread is now back to its former glory with a little update for Fabia II.
Ok now im lost......... :S
Why?
Sorry I was asking if the pad size between the ate and Lucas callipers are the same.
The same mod is carried out on the new vRS and Cupra.
Ross, have they changed the system at all to improve pedal feel on the new vRS/Cupra?
I think the brakes on the Fabia II are better for being ATE, also the abs is a lot less invasive.
However 312/256 is sooo much better ;)
