Kinetic motorsport exhaust manifold
same as the o34 motorsport one same manufacture
i can tell you now 100% this will crack they are complete rubbish
i had 2 both cracked with 500miles
check out seatcupra.net i think just about everyone fitted to a uk car failed very quickly and showed next to no gain over a ported standard mannifold
have fun with it lol
this must be the ina one then clive, so its a 034 prouced item.
From what i hear, a lot of trouble and a complete **** to fit, even with a custom made modified spanner they are still near impossible to get right.
iirc some issue with the flange to block mounting plate...shame as they are a good price
Completely agree
First one cracked, and I drive my car at www.grobnik.hr
track near my town. But first one was from THS performance
I took this one from 034motorsport baceuse of limited budget at that time-they stated:
"We made this manifold for you, using high temp rated, high nickel content cast iron, this manifold is a direct fit for OE turbo installation, which 50% larger runners for significant improvements in flow."
http://www.034motorsport.com/engine-components-18t-exhaust-manifold-high-flow-stock-fit-18t-p-784.html
But in the future (near one) going for
JBS autodesign one that will be ceramic coated as my 3" downpipše race modular from 452DD is. Comming this week-DP.
When mounting first one almost impossible on the car and second one was mounted on to the enigne while being taken out from the car.
Edited by davojuri
looks very similar doesnt it.
the Jbs design ones seem to be really good bits of kit, especially the coated ones, have still seen a crack in one of their stainless equal length manis tho.
guess thats what happens when you start to run high power and inevitable high temps
Edited by Oet
got a jbs one here im still yet to fit, read into them a hell of a lot and the early ones had issues but that was resolved with a revided version.
jbs is the only high flow mannifold that seems to fit the bill and has and is working well
the other option is to port the standard one this has shown the same flow rates as any high flow on the market
good luck buddy
Looks the same but difference might be in the nickel content cast iron
Had one and it cracked -bad product
Thought that this one from 034motorsport will be better one, but guys told me here that it's the same bull s..t
Is that the same as these?
http://www.thsperfor..._THSCMA-18T-TV#
Edited by davojuri
removed my 034 exhaust mani for eramic coating (found great company in Slovenia near me ISKRA AET TOLMIN-DOUBLE LAYER OUTSIDE AND DOUBLE LAYER INSIDE COATING FOR 150 EUR!!!!!!) and what a surpriseemoticon-0105-wink.gif
it was cracked inside of one hole for turbo bolt!!!-had it for only 2-3000km
same as last time but on outside of it.
Than I checked the flange and it was not even labeled, has 3-5mm difference from side to side and ist not horisontal.
Can't tell if it is from the thermal expansion or bad production, but complete s..t.
Also spaces for tightening the nuts on upper 3-4 bolts are made wrong - to lateral so you cant put key on them to lossen them it was nightmare.
So good news is
I BOUGHT BEST ONE-
JBS Cast 1.8t K03 OEM Upgrade
http://www.jbsautode...k03-oem-upgrade
It's on its way already hehehe
CAN'T WAIT TO FIT IT TOGETHER WITH LARGE PORT POLISHED INLET AND TO SE DYNO CHARTS BEFORE AND CORRECTING THE MAP FOR NEWLY MOUNTED 225HP EGTPROBE.
emoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gif
Edited by davojuri
Bad news, but good news then!
You need to write a full project report for your car, because it's one of the more interesting projects about at the moment.
Some detailed pictures and specs for your engine would be interesting when you're finished. :thumbup:
I bet you don't want to think about how much it has cost you so far!!
Some detailed pictures and specs for your engine would be interesting when you're finished. emoticon-0148-yes.gif
I'll do so certanly.
Manifold has arrived in less than 24 hours in Slovenian post-and already shipped to the guy Ambroz Kavs
www.kavsmotorsport.com ONLY 150 EURO FOR DOUBLE LAYER OUTSIDE AND INSIDE COATING OF THE MANIFOLD.
JBS CHARGES 300gbp AND SHIP IT TO ZIROTEC WHO CHARGES ONLY 150GBP-SO JBS IS MAKING PROFIT OF 100% EVEN ON COATING !!!!!!!!!
He will ceramic coat it in double layer outside and also inside
in Iskra AET Tolmin. Until weekend it should be done.
Than putting all together and on dyno www.rsrmotorsport .com
I am wondering how much will I gain from 3" DP and manifold before changin the map and pluging in EGT probe and large port inlet.
Of course that I will share my figures here on net.
Must said that finally car is running the way I wont
Further improwements:
8pot 330mm brake kit probably D2
Recaro profi SPG XL at least one
Weichers roolcage (still not sure)
and many laps on www.grobnik.hr to improve lap timeemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gif
Edited by davojuri
have you found a place to get a roll cage yet for the mk1????
i want one also
i want one also
Hi
yes I did.
here:
Fahrzeugtypen / types of vehiclesAusführungen / types of roll bars and cagesSkoda Skoda Octavia I Typ 1U (Bj. 1999 - 2004)B-E---Skoda Felicia (Bj. 1994 - 2001)B-E---
http://www.wiechers-...d=22&Itemid=115
Model E
http://www.wiechers-...d=43&Itemid=114
Prices:
http://www.wiechers-...d=19&Itemid=116
Alle angegebenen Preise verstehen sich in € inkl. MwSt. / All prices are in € included VAT. Bezeichnung / title
Stahl / steel ST52
45x2,5/40x2 mm
unlackiert / lackiert*
not varnished/varnishedStahl / steel ST52
40x2 mm
not varnished/varnishedStahl / steel 25 Cromo 4
45x1,5/41,3x1,5 mm
not varnished/varnishedAluminium / aluminum
45x3/40x3 mm
unpoliert / poliert
not polished/polishedÜberrollbügel / roll bar
Ausführung B und C / type B and C294,00 / 309,00268,00 / 284,00385,00 / 405,00340,00 / 450,00Überrollkäfig / roll cage
Ausführung E und F / type E and F
(vor dem Armaturenbrett /
in front of the dashboard)570,00 / 594,00523,00 / 545,00 752,00 / 777,00 650,00 / 873,00
Hope it helps.emoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gif
Edited by davojuri
not good will that german lol
how much is the one in the pic do you know????
looks good but cant see how the front arms will pass the dash ??/ maybe some cutting is req??
i want one also
Here it is
Look at the picture for E
all models
http://www.tunershop...=43&modell=6212
Wiechers 4 point roll bar type B, aluminum, polished, for Skoda Skoda Octavia I Typ 1U ( 1996 - 2010)
http://www.tunershop...roll_bar_type_B,_aluminum,_polished,_for_Skoda_Skoda_Octavia_I_Typ_1U_(_1996_-_2010)_(Audi_Skoda_Octavia_I_Typ_1U_(1996_-_2010))_x1700x_p233941_h3_m6212.html
Wiechers 6 point roll cage type E, aluminum, polished, for Skoda Skoda Octavia I Typ 1U ( 1996 - 2010)
http://www.tunershop...roll_bar_type_B,_steel,_unpainted,_for_Skoda_Skoda_Octavia_I_Typ_1U_(_1996_-_2010)_(Volvo_Skoda_Octavia_I_Typ_1U_(1996_-_2010))_x1700x_p234392_h45_m6212.htmlThe
last one will be most bling bling but I am after
Steel 25 Cromo 4-most advanced material-strongest and lighter than steel or maybe even aluminium because of thinner walls
Edited by davojuri
Look at the second reply-all uk
here it is
and look for the E type
on the upper right picture-in front of the dashboard-no cutting!!!
Edited by davojuri
thankyou very much
i will be going for type E with door bars and cross section rear etc etc
£900 going to order this next week whoop whoop
thankyou very much
Great.
I wont pisc ASAP when you put it into the car especialy fixing points-are they to be welded or on screws??
Keep us updated.
Steel or aluminium did you take?
Painted or not?
Edited by davojuri
going for steel and will be either bolted on welded plates or fully welded not sure yet lol
I'm 100% interested into that.
Haven't seen any real picture of it.
So please keep me updated-I need at least few real pics before buying it.
  • 1 year later...
