VRS clocks into non-VRS.....can it be done?
If so, is it a big job? I have my own full VAG-COM kit.....
Many thanks
Rob (Fabby)
Not a big job but will show original mileage from donor car.
You also need codes for both cars. Might be worth asking Shark Performance, they seem to do a fair bit in dash swapping.
fuel guage will read around the wrong way
Edited by Jayfabia
Yeah, I remember that from when I built the estate. Ended up fitting the vRS level sensor in the tank
Did that sort it? Is the plug the same on the vrs pump to the PD100 pump?
