Glowplug or Wiring Loom
So looking at the VCDS scan below, does anyone else think it slightly odd that as well as this glowplug issue the car seems to idle rough?
I'm wondering is the glowplug and the injector loom all the same loom as if so, would this point towards the wiring loom being the issue rather than a plug.
Anyone any thoughts?
As for the cruise control stalk, most annoying.
Ta
VCDS Version: Release 10.6.1
Data version: 20100831
Thursday,28,October,2010,20:03:05:36574
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 HF HW: 028 101 229 2
Component: R4 2,0L EDC G000SG 8658
Revision: 12345678
Coding: 0000072
Shop #: WSC 28069 576 88121
VCID: 6ED815FC00E5
2 Faults Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault
P0671 - 000 - -
Freeze Frame:
RPM: 819 /min
Torque: 42.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00001000
Temperature: 15.3°C
Bin. Bits: 10110000
18104 - Powertrain Data Bus: Implausible Message from Steering Column Controller
P1696 - 000 - - - Intermittent
Freeze Frame:
RPM: 2205 /min
Torque: 138.0 Nm
Speed: 96.0 km/h
Load: 36.9 %
Voltage: 14.21 V
Bin. Bits: 11001000
Bin. Bits: 00000000
(no units): 1.0
Readiness: 0 0 0 0 0
I'm guessing nobody knows if they are separate looms then?
  • 5 years later...
I know this is a old thread but just came to it and thought I have seen something about this. recently I had the Inlet Manifold problem and was searching to see if I could find out anything about the wiring I ended up finding loads of diagrams of wiring and looms at https://www.partsbase.org/skoda/octavia-oct-eu/
The database is a bit hard to navigate I used my model and engine code While I was searching there were loads of diagrams of various looms etc which might well be useful in answering this question for anyone who still needs to know.
