MY FL Vrs died last night 6900 miles? Any ideas
Hi I have FL vrs with 6900 miles and last night it just cut out and the dash came up with several faults. Managed to get it started but the exhaust warning light was on checked the manual and this is not the DPF warning light. Got half way home and it cut out again and I couldn't start it, so AA came out reset the fault codes and it started and run fine. Got in the car this morning same thing exhaust light on, so I reset the fault codes with vcds and car is running ok again.
Below is the fault list which is odd as prity much everything appears to be faulty??? Could this be anything to do with the OPS parking sensors i've fitted affecting the drive can bus as alot of the modules are saying missing messages or communication?? I've also had the car mapped by shark so i'm a bit worried about taking it to the dealer just yet as if it's ecu failure i'm guessing the warranty isn't worth anything now.
01-Engine -- Status: Malfunction 1010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 1010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CEG) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 RE HW: 03L 906 022 GA
Component: R4 2,0L EDC G000AG 5752
Revision: 13H04--- Serial number:
Coding: 0001078
Shop #: WSC 73430 790 00999
VCID: 79D73F9D49AB
1 Fault Found:
004997 - Control Module Malfunction - Lambda Sensing Circuit
P1385 - 000 - - - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 5
Mileage: 11164 km
Time Indication: 0
Date: 2005.14.13
Time: 21:45:32
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Lambda: 2.4 %
Mass Air / Rev.: 0.0 mg/str
Voltage: 0.000 V
(no units): 0.0
Voltage: 3.300 V
Readiness: 1 1 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 052 S HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2106
Revision: 51112 Serial number: 00001004161567
Coding: 0000020
VCID: 24693EE99EA9
2 Faults Found:
18258 - Powertrain Data Bus: Missing Message from ECU
P1850 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Reset counter: 40
Mileage: 11164 km
Time Indication: 0
Date: 2005.14.13
Time: 21:42:25
01196 - Engine-Transmission Data Bus
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Reset counter: 39
Mileage: 11164 km
Time Indication: 0
Date: 2005.14.13
Time: 21:42:26
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 163B601C092400FB681006EA901E0082340800
VCID: 78D13A9972A1
2 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 2
Reset counter: 245
Mileage: 11149 km
Time Indication: 0
Date: 2005.14.13
Time: 20:10:07
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 8196
Count: 49166
Count: 0
Count: 1024
Count: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 245
Mileage: 11149 km
Time Indication: 0
Date: 2005.14.13
Time: 20:10:11
Freeze Frame:
Count: 16386
Count: 32768
Count: 13056
Count: 8194
Count: 47878
Count: 0
Count: 768
Count: 1024
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 AR HW: 3T0 907 044 AR
Component: Climatronic H15 0401
Revision: 00005001
Coding: 0000000002
ASAM Dataset: EV_Climatronic A01006
ROD: EV_Climatronic_SK35.rod
VCID: 8225D871A47D
1 Fault Found:
13701376 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 10
Reset counter: 244
Mileage: 11149 km
Date: 2005.14.13
Time: 20:10:11
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 D HW: 1K0 937 087 D
Component: BCM PQ35 H 103 0575
Revision: 00103 AG
Coding: 4E180AB8B05BB1C040080080050081E4436000AE425D8160800440040000
Shop #: WSC 12345 123 12345
VCID: 3245C8B1D45D
Part No: 1Z2 955 119 C
Component: Wischer 21041 22 0601
Coding: 00D7B7
Part No: 1Z0 951 171
Component: Innenraumuebe 008 5101
Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 9
Reset counter: 244
Mileage: 11149 km
Time Indication: 0
Date: 2005.14.13
Time: 20:10:11
Freeze Frame:
Term 15 On
Voltage: 12.80 V
ON
ON
Term 50 Off
OFF
ON
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 1Z0 919 475 A HW: 1Z0 919 475 A
Component: PARKHILFE 8K H06 0004
Revision: -------- Serial number: 66540902200070
Coding: 000004
Shop #: WSC 35110 377 00999
VCID: 3FA39185170F
2 Faults Found:
01312 - Powertrain Data Bus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 254
Reset counter: 245
Freeze Frame:
Temperature: 0.0°C
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 6
Reset counter: 245
Freeze Frame:
Temperature: 0.0°C
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2LGU8/
Coding: 0020788
VCID: 3D5FEB8D1D03
No fault code found.
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 056 0111
Coding: 0001632
VCID: 76CD34A178B5
Part No: 3T0 959 537 A
Component: E221__MFL-URO H07 0012
Coding: 00000131
Shop #: WSC 00000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1Z0 920 943 J HW: 1Z0 920 943 J
Component: KOMBI H05 0305
Serial number: 00000000000000
Coding: 410B00
Shop #: WSC 73430 031 00999
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 40A192796AF1
3 Faults Found:
12648448 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 244
Mileage: 11149 km
Date: 2005.14.13
Time: 20:10:11
12671232 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 239
Mileage: 8367 km
Date: 2003.14.25
Time: 00:22:54
13635840 - Supply voltage: Voltage too Low
U1011 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 40
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4520K10426020F
Coding: EDA07F06400602001303
VCID: 69F76FDD390B
2 Faults Found:
03075 - Parallel Parking Assistance Control Module (J791)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 239
Mileage: 8367 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 244
Mileage: 11149 km
Time Indication: 0
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0305
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
VCID: EAF590D1BC0D
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 A HW: 3T0 035 680 A
Component: RNS-MID H05 2684
Revision: AB001001 Serial number: --------------
Coding: 000004000001008100
Shop #: WSC 73430 790 00000
ASAM Dataset: ------------------------- ------
VCID: 2E7DDCC1C065
1 Fault Found:
01327 - Control Module for Parking Aid (J446)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 239
Mileage: 8367 km
Time Indication: 0
Date: 2003.14.25
Time: 00:03:08
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2114
Coding: 0000756
VCID: 48B18A5942C1
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
VCID: 3147C7BDD15B
2 Faults Found:
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 131
Mileage: 8214 km
Time Indication: 0
Date: 2003.14.19
Time: 12:16:46
Freeze Frame:
Voltage: 12.38 V
DD
Temperature: 31.0°C
RPM: 0 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 244
Mileage: 11164 km
Time Indication: 0
Date: 2005.14.13
Time: 21:42:28
Freeze Frame:
Voltage: 11.63 V
DU
Temperature: 33.0°C
RPM: 1498 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000756
VCID: 47B389654FDF
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
VCID: 2E7DDCC1C065
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 239
Mileage: 8367 km
Time Indication: 0
Date: 2003.14.25
Time: 00:03:08
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012551
VCID: 3245C8B1D45D
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 334BCDB52B47
Address 77: Telephone Labels: 3C0-035-730.lbl
Part No SW: 5N0 035 730 B HW: 5N0 035 730 B
Component: J412 8502
Revision: 00015000 Serial number: 0000B7A144740
Coding: 0020222
VCID: 277329E5EF9F
1 Fault Found:
00992 - Consumption Cut-Off Active
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 242
Mileage: 11137 km
Time Indication: 0
Date: 2005.14.12
Time: 17:51:58
End ---------------------------------------------------------------------
Edited by ollybroad
That is a lot of malfunctions, at least your Teeve 60 abs hasn't gone ! :S
I would remove the VIN number from your post
That's great but if I can't drive the car Abs is a bit of a waste of time. At the moment it's a big black shed with wheels
cheers!
Christ that pretty much a whole system failure! I would disconnect the parking sensors and remove the map esp as its still under warranty as most dealers will use any excuse to get out of a claim. Then reset the system and see what happens.
Why would a dealer say no, at the end of the day warranty is work for us! admited we do strugle with certain claims but most people think its us the dealers who dont want to help, but our HANDS are tied and if Skoda
say no what can we do!
Going back to the above prob i would retrack and think has this occured since you have fitted your sensors and if so disconect them cos if youve broke into a can bus wire all sorts of things could occur or is it since youve been remapped. Looking at your log i would say its going to be a fault on your ecu but i could be wrong. hope u get it sorted.
Car died again and now won't start vcds says no coonication with ECM. I have taken out the ops module however still no joy. I'm thinking the ecu is dead? Anyone had similar fault?
Not very likely to be the ECU in my opinion, check the relays in the engine bay fuse box. Not sure what numbers it will have on it but possibly 109 or 100. There should be a couple the same in there so try swapping them.
Sounds like some ECU issue, maybe corruption, did you back up the code before the sensors were fitted? I would not think a dealer would replace the item as I'm sure they're tested when they get sent back, so if its been tinkered with they'd be stuffed.
Re the post about dealers and warranty, its my experiance that even if its covered under warranty, cos they only get the cost back on parts/labour which are proven to fix something they don't want to know. i use SOGA rather than warranty.
I will have a play with the relays tommorrow see if that helps. Strangly the battery is flat and I was not cranking it that much. Seems as if I have a large power draw from something.
Or a dud battery??
Had something similar on my Fabia VRS. The guy who came out to it said the ECU was dead as his diagnostics couldnt talk to the ECU, said it would be lots of £s to replace. Luckily got it taken to independent garage who diagnosed a power relay failure - this was replaced for about £60. ECU was not at fault.
Hope your problem is something similar and not costly.
Maybe thats the problem.
when I had the Corrado G60 certain things started to go funny ( rear wing, alarm, computer) new that it was the baterry. Even if you charge it up I´m sure days later you may have the same problem.
It's not the battery as I've tested it and it's taking a charge car is pulling a few amps when switched off should be about 0.5
Ok i've swapped the relays and no joy still cant start the car. When I turn the ignition on car comes up with fault ESP. With vag com I cant get into engine 01 at all to see what the fault codes are however when i do a full scan sometimes it comes back with,
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Mileage: 11164 km
Time Indication: 0
Date: 2005.14.13
Time: 21:45:32
The other modules are still coming up with error codes mostly to do with cant communicate with ecm
Coding: 0000020
VCID: 24693EE99EA9
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 11164 km
Time Indication: 0
Date: 2005.14.13
Time: 21:42:25
Freeze Frame:
Fault Priority: 0
Reset counter: 39
Mileage: 11164 km
Time Indication: 0
Date: 2005.14.13
Time: 21:42:26
read on ross tech wiki a few possible causes but unless it's because i've had the car remapped and now it's caused the ecu to fail I can't see why i would suddenly get a can bus fault?
Any ideas anyone?
1314 - Engine Control Module: No Communications [/url]
Possible Causes
  • CAN-Databus Wiring/Connectors from/to Engine Control Module faulty
  • Fault(s) stored in Engine Control Module
  • Engine Control Module recently flashed or re-mapped
Possible Solutions
Trailer it back to whoever did the map??
If the ESP light is on then it usually meana that the ECU isn't reponding.
Of course we'll be happy to look at it for you FOC, or if you'd like to take the ECU out and send it up to us then we can take a look at it and see if we can see what's going on.
If you'd like to get the car recovered here then that's no problem, but of course that might be costly.
tried to pm you but says you cant recieve any more messages. Can I give you a quick call?
Have you checked each and every fuse? Has this just happened since the parking sensors were fitted? Possibly an earthing fault somewhere?
Oops, must be full. Yes, give me a call on my mobile, number's on the website if you don't still have it.
That's 200 miles away!! I also want to be sure exactly whats wrong with it before I do anything.
The car was fine just cut out with engine light on I managed to start it but the engine light stayed on but then cut out before I got home and then wouldn't start. AA did a scan and his box said no coms with ECM/PCM but he then managed to clear all faults and the car started with no light on dash. Got home ok so next day went out in it and it seemed ok and then it just died in the middle of a roundabout which was fantastic. AA guy said same thing ECM/PCM no coms and he couldnt reset faults.
As soon as I turn the ignition maxidot comes up with FAULT ESP. I can't reset the faults as they just come back and 1 Engine module just comes up with no coms. My battery has also died very quickly and I've had to charge it so i'm guessing something is causing it not to power down.
Another strange thing is if i turn the ignition on the fan comes on straight away for a minute or so? is this normal? The relay in the engine bay next to the battery is also clicking on and off and continues to do so untill the dash pod powers down a minute or so after turning ignition off. I've swapped it for another relay the same under the dash as I only had one in the box next to battery.
it would apear you have an ecu malfunction best bet is to send the ecu back to ben at shark :thumbup:
