TT / Cupra R engine in a vRS
Still need different intercooler,exhaust plus loads more bits.
You will be miles better off spending £5k on your car.
That engine is worth £2.5k tops.
Edited by jaymd
Not a simple drop in then!
+1
BAM engine isn't really all that wonderful, just a little stronger.
You could buy a used engine (so you know it works !), and get it strengthened beyond BAM spec for around that price (maybe a hybrid KO3S as well ...)
lol
Where does one aquire a brand spanking engine like that hhmmmm.
no point you can forge an engine for less lol
and you would need custom exhaust
ecu
wiring
ask trevor b he did his and it wasnt a straight swap
p.s and why would you anyway for that money lol pointless
give me £4500 i will bild you a stronger engine than that :p
For the amount that engine costs couldn't you easily do alot more for alot less?
My friend has the TT with the BAM angine and I have to say I don't really notice anything on it agaisnt my vRS.
there is a big differnce between the 2 but not worth it in this case imo
a bam engine has stronger internals and bigger turbo
bam standard = 225
vrs standard 180
so there should be a big difference or your mate has a problem
Have an engine fault at the moment and looking at worse case scenarios. Hopefully I can get mine fixed.
Guest
