V7 maps for Columbus
Red light camera on the left and speed camera on right.
Only problem is that Ill spend all my time looking at the screen and not the road! emoticon-0144-nod.gif
Oh, so there's no provision for getting a warning of 'on-route' cameras then, presumably. If that's the case, it's the most banal, useless and, possibly, dangerous implementation of speed cameras I can imagine. Oh that the speed camera functionality of even my ancient Tom Tom were includedemoticon-0106-crying.gif
  • Replies 120
  • Views 23.1k
Dunno, I havent driven with the sat nav active where there are any camaras yet, I'll let you know when I do.
Thanks - that would be great!
I'll use my iphone with the pocketgpsworld.com speed camera database for speed cameras.
Mike
This is what you want:
Click the image for a larger version.
Best regards
David
Did you get v7 with your new car David?
I've managed to find the v7 maps with cameras and burnt the dvd. The maps work fine from the dvd but I've forgotten how to transfer the map data to the hard disc!
Can anyone help with the simple transfer procedure?
Many thanks.
Many thanks.
When I updated to the previous map release as the disc was inserted a message came up offering the option to use map from DVD or copy to HDD.
Maybe try taking the disc out and putting it back in?
I took delivery of my new car last week with v6.1 of the maps.
I called the dealers today who were unaware that v7 is released. "We just send you the disks that Skoda send us" etc, etc. They will check with Customer Services and get back to me.
I'm not expecting this to be easy :(
Does anyone know if these Columbus maps work with the Amundsen unit, if transfered to a capable SD card on a computer or mac before plugging it in to the unit in the car? I've just ordered an Octavia with the Amundsen, but I discovered that it only reads CD's and I probably have to buy each contry separate when going om a road trip in Europe... :'(
If there's no workaround, it would have been cheaper to buy the Columbus than the Amundsen with full European map support (x-times CD's) I guess...
Well here is the proof that some Doubting Thomas' wanted
Oh and it's not my Postcode btw i just know it is a 7 digit one
This is what you would normally have seen and then after this screen you would have been presented with a list of TN21 1 no's
However now you can enter in all 7 digits
You then get this
Does 7333 contain speed cameras ?
Then when you press that you then get the Select street etc screen. When you press select street you get this
And then you just select no. and away you go.
The info from the cdtoc file is
Continental Automotive GmbH
I IC RD G SW NM DB
Content
Volume: CD_7333
Date: 11.8.2010
db: EU(2009Q4)
Area: West Europe
Supplier: Navteq
Version: 505.20.942.9.84
Customer: 1627387139
Customer Info: VW
Features: V10
TPD: 2010087006
SVD:
TMC: 20100804
Phoneme: yes
DBAL: V5.18 V6.28 V7.20
Hope that clarifies things for some :)
My 7333 version does not have speed cameras in the POI list. So I guess some do & some don't
Yes - thanks to the nice chaps @ Rainworth Skoda :thumbup: .
As my car had been sitting at the dealer for best part of a month I assumed I would be getting v6.1.
Best regards
David
Only if someone has added them manually. ;)
Is it me, or is the columbus now slower at loading destinations using v7 maps? I installed them today and it seems to take longer to respond to inputs now.
My Yeti came with a columbus unit installed, which is only a week old now. No idea how to tell what version of software it is running. I don't have access to VAG COM.
Mike
Grateful if someone could direct me to a location for V7 via PM - and not a map to my local dealer :)
Grateful if someone could direct me to a location for V7 via PM - and not a map to my local dealer emoticon-0100-smile.gif
I found a download after a bit of searching, and I guess many will do this. I haven't downloaded them, and I do have reservations about the morality, and legality. Praps that's just me being stupid. I am engaging with my dealer and I am hoping to get there by more (to me) acceptable means...
Mike
See if your Columbus allows you to input a full postcode, if it does you have v7. If not, you have v6.1 or older.
Mark.
Mark.
Is the 7 digit postcode a feature of the maps, the firmware, or are both V7 maps and a specified version of fw required?
Cheers,
Lou
Not at all - everyone has their moral boundaries. I used to use game backups for my consoles, but are now 100% legit for no real concrete reason other than I feel I should, and can afford it these days.
Probably the wrong place for an ethics debate :)
Mark.
Mine seems to only allow a 5 digit postcode, BUT there is a copy of V7 in the glovebox, so I am assuming V6.1 has been loaded? (I hasten to add that I not checked properly or RTFM yet)
The 7 Digit Postcode functionality is a part of the mapping and the firmware.
If you do not have any of the firmwares i have listed below you will only have the new map data and not the search functionality.
In order (don't worry about no.s)
2664 (Beta so if you have this i recommend going to 2724 or 2764)
2684
2724
2764
1304 (Latest - only difference is no voice control but you need bluetooth for this anyway)
3804
3814
Both 3804 & 3814 are pre release Betas, only work on B revison nav units, require V7 maps so install them at your own risk.
HTH
Carl :thumbup:
I'm on 2664 but the v7 maps won't load to the hard disk (they work fine from the dvd), would moving to 2764 help? Or is there some way of forcing the disk copy?
Stig - do you know if one invests in the latest V7, you also get a firmware upgrade - or how does one arrange that (ie do you know if its another 'pay through the nose' thing)?
Thanks for all the info!
Ignore that just tried it again and it DOES accept a 7 digit postcode emoticon-0111-blush.gif
(V7 & 2724)
No they are 2 seperate discs. Most dealers won't touch the firmware upgrades. You can download the firmware from VWNavi.com
Just follow the instructions posted on there and as long as you haven't got a RNS that has had the EEPROM soldered (usually indicated by no code card and a code of 1234) then you "should" be fine to upgrade.
Just be aware though all firmware upgrades are at your own risk.
Carl
