Sudden MPG drop
Hi All
I just got the rear geometry done a few weeks ago by a very helpful dealer.
The problem is, since then we are getting about 80 miles less per tank :-(
Is this just coincedence or could there be another issue???
We normally get around 480 - 490 miles before the fuel light comes on but now its around 400 miles.
This has been consistent over the last 3 or 4 fills.
Has anyone else had this problem when the rear geometry has been done?
Any other ideas / suggestions?
Regards
Dave
Hi All
Regards
Dave
Could be coincidence - has it been colder up there for the last few weeks? Cold weather will reduce the mpg. Another thing to check is the tyre pressures - they might have changed them and put them too low.
+1 for tyre pressures. If you have checked them lately then the colder weather will result in lower pressure. It's a real killer for fuel economy.
Also I guess we're into winter diesel now which has more guff in it to prevent it from freezing. I always get less mpg in the winter, by about 10%.
It WILL be the colder weather and longer warm up times...
have you had new tyres fitted as well well , this could make a difference , ive seen a slight drop in economy since i fitted my conti sport 3s
Had new tyres fitted on the front when we got the car - been getting around 480 - 490 miles to fuel light on since we got the car a few months ago.
All that was done was the rear alignment and the front tyres put on the back and vice versa.
Checked the pressures today - 28/29psi which is about 2bar as stated in the book - put up to 32psi all round to see if that makes a difference.
Car going back in to dealers later this week for a couple of rattles so will ask them to recheck the geometry for piece of mind.
Dave
