Help Needed
Does anybody know why the temperature light on the dash comes on when i start my car and stays on for about 30 seconds.its only started doing it for the last couple of days. Thanks in advance
needs water ?
If it's not low on coolant, then it could be that the header tank sensor has got gunked up. You can clean it up with a toothbush.
Edited by pauldazzle
I had this problem with my old mk1 vrs,it did it every winter,all i did with mine was add a little bit of coolant & it was fine,its normally the sensor req cleaning or replacing.
