Rear Washer Jet
Hi, mine has popped off with the cold weather. Have tried to use the search and have looked in the manual but can't find the info I need.
How do I get the boot trim panel off? I assusme washer jet is just pushed on after that?
Thanks for help
I'm pretty sure there's a pipe join somewhere behind the trim by the CD changer which is prone to popping off.
Certainly this is the case for the estate. The pipe is wrapped up in the wiring loom under the CD changer. Check for a puddle of water before pulling off boot trims.
Oh, fwiw, some people suggest tie-wrapping that joint, I would not do that - best an easy-to-access joint pops apart rather than one hiding away under trim/etc.
Edited by mbames
