Which Fault Code Reader
i think they both use the same 16 pin obd2 port so it should be ok :thumbup:
EDIT: manual says its for 1990 onwards so should be ok for yours.
Edited by sivrs
  • 4 weeks later...
Hi,
Thanks for the advise, bought the fault code reader and it didn't show any codes... later on the warning light disappeared from the dashboard....
Cheers,
Ewan
Ah, that looks excellent.... :thumbup:
Cheaper than having a diagnostic at the garage....
is that ODBII for my car? is there a difference between the MKI & MKII Octavia?
Cheers,
Ewan
Would this tool also be able to reset the service light i.e. if you changed oil and serviced the car yourself?
If you're on fixed servicing then you can reset it yourself without any tools - Instructions in the user manual.
Thanks - On variable servicing.
I notice you can get cheap seperate unit on ebay to do this so wondered if this unit could read fault codes and reset service indicator
