Lost All Boost?
Hey people,
coming home tonight i accelrated onto the bypass and started hearing a loud noise like when blow a bit paper side on make loud whistle noise and lost all boost, when try to drive it or go over 2000 rpm doesnt want to
i then drove it 5miles home and it hasnt used any oil so dont think the turbo has went as used it all,
and bit smell of burning rubber!
now home the loud whistle noise is gone but still no boost
think a boost hose has maybe went somewhere?
Euan
Hey people,
Euan
Yes will more than likely be a pipe has come lose or a hose has split, just check all connections are nice and tight....
Cheers mate,
If my turbo has went what other signs would I have or is there anything else can check to see if its away?
Euan
Cheers mate,
Euan
If your turbo has gone, the thing will almost guaranteed to be burning oil and there will be hellish smoke out the back as a result. In worst case scenario, when you turn it off, the engine will 'runaway' and the only thing that will stop it from running is when the conrods vent the block....
Almost certainly you've got a leaking pipe as someone else said
got car checked today and it came back code 17664? and also something turbocharger pressure not enough or something
so going to replace the coolent temp sensor and if this is away it can cause faulty singals ive been told?
this make any sense?
Euan
