Boot opening by itself when....
When I open the petrol cap, when I press the unlock twice on my key to open all the doors - doesn't always do it but it's started doing it randomly today and it's annoying
Oh it just opened when I started the car too not impressed :(
Maybe the battery in the keyfob is running flat and causing malfunctions? Got another key you can try with?
Tried my wifes key, the boot seems to have a mind of it's on. Seems to happen most often when I start the car pop boot opens.
Problem might go away by itself but it's annoying, no fuse I can remove for it lol my answer for most things if it doesn't work properly remove the fuse
Guess no ones ever had this problem before
Are you sure the keys are causing the problem - might it just be that the boot's not latching quite properly and vibration is setting it off? Thereagain it would be popping open when you drive along in that case...
Edited by DRJ
Tried both keys, at first it started when I opened all the doors then it happened when I pulled the leaver to open petrol cap ( yes the boot opened ) now everytime I start the car the boot opens and my warning lights shows up - boot is closed properly it's a bit odd it just started today nothing unusual has happened unless I've been possessed
We had the opposite extreme, the boot falling by itself. It once fell on the neck of a person cleaning it! This was not long after I bought it. It has since had the parts replaced and now its perfect opening and shutting. Sorry to hear about your grief.
Have the keys got wet recently?
After an extremely wet day on the hills, my keys got wet and some strange things happened locking and unlocking the Fabia for a while. It all sorted itself out again once the keys were dry.
Other than that replace the battery in the keys as a first port of call. If that doesn't work.........
... then it happened when I pulled the leaver to open petrol cap ( yes the boot opened )
This is a completely mechanical action, the lever by the seat actuating a cable which pulls the latch back. The keys and the central locking are not at all relevant here - unless you accidentally pressed the key at exactly the same moment! Hence my suggestion that it's something to do with the lock mechanism not closing properly...
It must have a fluke it opened when I opened petrol cap, tried both keys so it won't be due to them being wet.
Today even once the boot closed it opened again by itself 3 times kept having to close it then I could drive off
Grrr triple post sorry
Edited by Chris182
Problems gone by itself
It could be water in the electrics of the car causing the electrical circuit to complete and trip the catch.
Mine had the opposite problem and the boot wouldnt open - what i founf was a water leak from the wash/wipe had leaked into the wiring loom and 2 connectors had corroded so badly that the connection was always closed - even if I used the boot latch or the keyfob. just cut off the connector - resoldered it and wrapped it in insulating tape. Never had the same problem since - maybe worth a look?
