Decoded options list
In case someone is interested, here is my decoded list of options (found on the sticker):
Coded:
e0a;1d0;5se;5rq;1ks;6ff;1at;3fu;1n3;1nl;h09;4up;4r4;5kp;3qc;4x4;4a0;8l5;j1l;7al;8gu;9ak;8rm;
7q0;8dn;8ql;8x0;4k3;b42;g06;qn2;3l3;9p3;7x1;9w0;8wd;7a0;3gg;qg1;7mg;l61;7p4;f0a;2ub;3s7
Decoded:
E0A = No special edition
1D0 = Without trailer hitch
5SE = Left exterior mirror: convex (modified viewing field)
5RQ = Right exterior mirror: convex
1KS = Disc brakes, rear (Geomet D)
6FF = Body-colored exterior mirror housings and various add-on parts
1AT = Electronic stabilization program (ESP)
3FU = Big roof system
1N3 = Speed-related variable steering assist (Servotronic)
1NL = Covers for alloy wheels
H09 = Tires 215/60 R16 95H (polymer coating)
4UP = Drivers and front passenger air bag with knee air bag and front passenger air bag deactivation
4R4 = Power windows with comfort operation and circuit breaker
5KP = 3 separate seats (first row of seats)
3QC = 3-point seat belts, front
4X4 = Side air bag, front and rear with curtain air bag
4A0 = Without seat heater
8L5 = Roof antenna and "diversity" window antenna
J1L = Battery 280 A (60 Ah)
7AL = Anti-theft alarm system, passenger compartment control, backup horn and towing protection
8GU = Alternator 140 A
9AK = Climatronic with impact pressure control free of cfc
8RM = 8 speakers (passive)
7Q0 = Without navigation device
8DN = Radio "LOW I"
8QL = Key for locking system with remote control
8X0 = Without headlight washer system
4K3 = Radio remote controlled central locking operated from inside and safe securing
B42 = Special requirements Bulgaria
G06 = Front shock absorption
QN2 = Drawer under right front seat
3L3 = Manual height adjustment for front seats
9P3 = Seat belt reminder, electric contact in buckle
7X1 = Park distance control
9W0 = W/o car phone preparation/installation
8WD = Integrated front fog light
7A0 = Without CD changer/CD player
3GG = Plane rear cargo area
QG1 = Service interval prolongation
7MG = Emission standard EU5
L61 = Suspension range 61 installation control only, no requirement forecast
7P4 = Manually adjustable lumbar support in front seats
F0A = No special purpose vehicle, standard equipment
2UB = Rough-road design
3S7 = Roof rails
You may check yours here: http://igorweb.org/equidec/Default.aspx, and if you find any inconsistencies where should not be (like different battery), please post it.
I wonder what stays behind item B42 - special requirements Bulgaria...
Here is also my VIN number decoded:
Coded:
TMB3BC5L6B6xxxxxx
Decoded:
TMB = Skoda CZ other factories (Manufacturer's world code)
3 = YETI, left-hand drive, 4x4, vehicle category N1 (Model and version)
B = 1.8 ltr./112/118 kW/petrol engine (Engine type)
C = total weight 1814 kg to 2268 kg (Airbag system) - quite odd, but that's what Elsa says...
5L = Yeti (Model)
6 = - (Internal code)
B = 2011 (Model year)
6 = Kvasiny (Manufacturing plant)
xxxxxx = (Vehicle body number)
BR,
Boyan
Convex exterior mirrors?!?!?! Hmmm... so they DO exist yet SUK in their wisdom do not specify them for the UK market. Typical.
I remember seeing some on bay a while back, but not sure if they were auto dimming on the drivers side though, so didn't look at them.
Mike
No auto dimming on mine, nothing special ordered as mirrors. I guess it's just Skoda naming for the regular ones. Try your options list and maybe you'll have them too :)
These are the codes for my previous early production UK SE 140 MY2010 (previously published) for comparison;
5SJ = Left exterior mirror: convex
5RC = Right exterior mirror: convex (modified viewing field)
1KJ = Disc brakes, rear
3FA = Without roof insert (standard roof)
HW6 = Tires 225/50 R17 94W
4R4 = Power windows with comfort operation andcircuit breaker
4X3 = Side air bag front with curtain air bag
4AQ = Door and side trim panel in foam film -- Broadway --
J0N = Battery 330 A (61 Ah)
8AG = Radio with CD/MP3
8X1 = Headlight washer system
B09 = Type approval Great Britain and NorthernIreland
QN0 = Without drawers under front seats
L66 = Suspension range 66 installation control only, no requirement forecast
7P0 = Without lumbar support in seat backrests
3S2 = Black roof rails
TP
Thanks TP,
Any chances you entered 4AQ instead of 4A0? (under 4X3 item) - I did the same mistake. I'm also curious which radio you had. Also you had bigger battery :)
Altogether 15 differences from 45 options - so quite different car, don't you think :)
Thanks TP,
No longer have the Yeti so unfortunately cannot double check that 4A? code. Regard the radio, UK SE and Elegance both come as standard with the Bolero and 8 speakers and diesels tend to have larger batteries due to more power being required to start them (higher compression ratio).
Regards,
TP
...CUT...
Anybody knows if there is also a code for the different exhaust terminal pipe (twin circular of big-squared one)?
I suspect that on my SM has been replaced by the dealer before delivery ...
:S
:S
apologies no but if yours is a model year 2011 (10th digit of chassis number should be the letter 'B') then more than likely it should be the single pipe with no below boot floor tool box.
If a MY10 (letter 'A') then twin pipe with a tool box set in below the floor.
Hope that helps,
TP
It's a 2011 model (chassis number with 'B') but in past days I had a look at pictures shoot taken the days before the dealer consigned me the car and... from the perspective point of view of one photo, it seems to have the "twin pipe"... but may be only an optical effect.
I don't understand what you mean for "below boot floor tool box"... do you mean the tools needed for changing the spare tire in case of puncture or what?
Thanks for your cooperation
Hi,
this My link I hope will explain what I refer to as the below or sub floor tool box and the change reguired for the new style exhaust on the 1.2TSI.
Regards,
TP
Just back from a "mall" close to my office and... there was a white Yeti on expo.
I did a fast verify at it and I've seen the twin pipe... I've checked the chassis number and it's a 2011 model (with B letter...).
As you can see on these shoots:
Just a curiosity: the "rail" inside the boot (the ones used to fix bags or other things) are not present. Instead of them there are just two foldable hooks (one on each side), as you can see here:
Is a "new" version or not all the Yeti versions have the rails?
P.S. Just an additional note: the above pictured Yeti hasn't the spare wheel... and, other than the nets, there was also a complimentary 0.5 liter oil bottle under the boot floor cover...
Edited by medi@wiz
Hi,
believe the single pipe only effects the 1.2TSI, not sure on the engine here as the 5th letter (engine type) is a J and thats not on my list of engines from early 2010 but it could be the new 1.4TSI :wonder: as its a 2wd LHD (4th letter J).
The rail system is not fitted as this is obviously a base Active ('E' or 'S' in the UK) spec (steel wheels and black door handles + mirrors), therefore only comes with the 2 'curry' hooks.
Regard oil; got a litre bottle with my first Yeti but many don't, just wonder if it is from the factory but aquired by the dealer for stock sale shall we say :wonder:
Hope that's of help,
TP
Edited by The Plumber
  • 2 years later...
Hi all,
Is it possible to find installed parts number on my Yeti using VIN ?
Thanks for reply
Ashish
