Front Brake Pads - from Eurocarparts
Gonna order some Front Brake Pads from Eurocarparts,
But they seem to list a whole list of different pads from PAGID.
Does anyone know the correct ones to fit my car please?!
My car:
2002 1.9TDI (100bhp ATD engine) Fabia 5door
I am guessing my car has 256 front brakes - (It has the FS3 fixed hub/carrier anyway) if that helps.
(I worked out that they seem to list 256mm and 288mm for my car when I looked at the front Brake discs, so it was easy to sort out which discs suited, but pads aren't so easy to work out)
Not sure on which pads are for you but if you use voucher code BOX20 it should save you 20% :thumbup:
yes mate, thanks for the code, I'm intending to use it and stock up shed load of parts for the Fabia and my R32 Golf.
Just need to work out what bloody pads are the correct ones for the Fabia....
Anyone else know?
best way is to wip a wheel off and have a look , only way you will be sure to get correct set really emoticon-0148-yes.gif
I think u've mis understood me
I know I have the FS3 256mm brakes
I just don't know what pads to order off the Eurocarparts website - cause they list about 5 different sizes for the fronts on my car!! The website is crap basically!
I can now see your problem. I put your car details in and there were 21 pads found. 7 Pagid, of which 6 are for the front. I think the difference is some have pad warning inductors and some don't.
Also, from what I have read on SCN, that discount code is valid until 9th Jan. 20% Discount at Euro Car Parts! - SCN
just buy genuine :)
