polishing ko3 inlet manifold
hi guys,does anyone have any good tips for inlet manifold polishing.been at it for a few hours now and only just getting the furryness off the surface.i dont know if i can get it bead blasted with a fine sand or maybe get it acid dipped or summat. i'm using a drill with a waffle (sandpaper) wheel at the moment.it will do the job,i just want to speed it up a bit. also i'm not sure if its worth doing the underside of the mani,its quite intricate under there.if anyone wants to add a pic of there polished manifold to keep me motivated i'de really appreciate it cheers.
sounds like a lot of work, looked into the JBS manis?
Powder coat it - no more need to polish it then lol
theres a place near oxford that will do the inlet mani and cam cover for £80,so that may be the way to go if i cant make decent headway.
Ouch! I think I paid £30 last time I got something powder coated (cam cover).
Yes cost me £30 to have my inlet powder coated????
come on guys thers plenty of polished manifolds on here,somebody must know some good tips!
I have done a few of these.
I started with a drill and a flat wire brush wheel bit in the end of the drill and used a sideways firm motion to remove the rough effect. When that was removed i then set about with very coarse sandpaper moving to medium and fine and then very fine, and lastly some alloy polish like autosol or similar. It is still a lengthy job, took me over 3 hours.
I focused on the top and the main tubes, not underneath
This is a member cars polished manifold i did
and some shots of mine, did the same with the cam cover
I just keep my bonnet shut its easier :think:
cheers bowders1,i been using a sandpaper flap wheel (80 grit) to start off with.i'll get a wire brush wheel and some finer grades of sandpaper and give it another go.
It takes time but worth the job in the end , and is easy to maintain. I just re polish it every few months. :thumbup:
