rear washer blocked
My rear washer does not work. i have checked all the connections and they are all fine. i disconnected it at the back near the rear passenger door and the water gets that far but then does not come out of the washer. does anybaody know how i could fix it. are there any likely places in that last section of pipe where it would become blocked. any advice would be greatly appreciated.
Moved to the Roomster forum.
There is a secondary pump in the rear hatch, I think. Make sure the fuse for this is OK (if it has a separate one) and look at the connections.
HTH
HTH
[/quo
any chance you could shift this one back as i was talking about my fabia not the roomie.!!
I believe there is some sort of repair kit for the motor available which I think will cure your problem.
