windows
Can any one tell me how to dissemble or get at the window switches on the driver side door, as when I press the driver side window switch right down to the bottom nothing happens at all, but if I only press it halfway down the window moves until I release the switch. I wondered if it was a loose or poor connection on the switch itself. I have tried to take the switch mounting panel off but it seems very stiff and I did not want to break any plastic bits off.
I have tried all the remidies from my previous posts about the switch about closing all windows operating door switch etc but every thing stays the same. The switch for the passenger window works perfectly so it seems like a faulty contact on the switch or a wire off, but I cannot get at it.
john.
I have found the answer to this,
you need a small screwdriver with a six inch blade which you bend the end of about 40 degrees one inch from the end. Push this up through the hole underneath the handle the switch is in and push up until you can feel the catch which is against the door panel and push it out towards the window;; release the other catches by prising the top part of the unit up with a knife pushed in the join.
The switch comes apart with using a very small Allen key 1.5 mm undoing about 8 screws. clean the inside plastic cover with the conductive rubber pads in and the circuit board with alcohol or switch cleaner ( BUT NOT WD40) and reassemble.
Hope this works for any one else.
Edited by wyreman
