Which tool for extracting oil sump plug?
Hey guys,
I am trying to change the oil in my Skoda Fabia 1.4. Unfortunately, I get as far as realising I don't have a suitable tool for extracting the oil plug at the bottom of the sump! Does anyone know exactly what I need?
Thanks,
Nick Hill
I believe it to be a 19mm hex, so a socket or spanner.
Have a look at this thread
PL
On an MPI it's an 8mm allen key.
Hey guys,
Thanks,
Nick Hill
The Fabia VRS as stated by fellow member has a 19mm nut on which a 6 sided socket will fit, to remove.
You say extract? does that mean you need some sort of 4 - 6 sided key to place inside head to enable it to be turned??
The gear-box on a Fabia VRS has a special key socket for it's removal, and must assume that you are not attempting to remove a similar nut on your gear-box ?
1.4 TDI 2007 model is 19 mm socket - did mine again on Thursday.
Trust me people, on an AQW which is a 1.4 MPI petrol it's an 8mm allen key.
Car:Skoda Fabia 1.4 MPI OHV AQW (2003) - I would imagine it is! :D
people seem to assume on this forum that everyone is driving a fabia vrs :giggle:
Have you considered using a pump? I find it very convenient. Used to drain from the sump plug, but I get the same amount out with the pump and it's so much quicker and less messy - have done about 10 changes with it now.
It is a pela pump that I use - about £40 off ebay.
Edited by Nigel R Slack
