Elm327 With Skoda Fabia 2005 Model
a.k.a BT
I am planning to buy ELM327 (1.5a or 1.4) tool from ebay.
Will it work with Fabia 2005 model?
I prefer ELM327 than blue color device.
Please advice if ELM327 device will work with my car.
Specifications:
OBDII Protocols:
ISO15765-4 (CAN)
ISO14230-4 (KWP2000)
ISO9141-2
J1850 VPW
J1850 PWM
Output protocol: RS232
Baud rate: 9600 or 38400
Indicator LEDs: OBD Tx/Rx, RS232 Tx/Rx, Power
Operating voltage: 12V, internal protection from short circuits/overvoltages
Nominal idle current: 45mA
Color: Back + Orange + Blue
Item Size: 8.8 * 4.6 * 2.5cm
Package Size: 20 * 15 * 2.5cm
Item Weight: 130g
Package Weight: 139g
USB Cable Length: 176.5cm
Whats 'ELM327' ? I presume its similar to VCDS, is it better in any way ? cheers - Stuart
ps - just done a search and ELM327 is a microchip converting CAN bus data to rs232 for use on a computer. but do you need a pogram for the PC ?
Edited by sparky2
ELM based hardware is not supported by VCDS, so if you wanna use that combination - it simply won't work. For this specific combination there is pretty much no need for an ELM based interface since a 2005 Fabia has no CAN-diagnostic to begin with. If you don't like to spend the big bucks on a real/current VCDS system, a cheap KKL interface should do the job too and works with a lot of OBD2/EOBD software.
