Allard Egr Delete
Had one of these on my mk4 golf does any one use them on there Vrs ? Any problems with fitting etc ?!
Regards olly
Regards olly
If you use the search feature you'll get loads of threads on EGR deletes, haven't done it personally but from what i've read theres pro's and con's mainly dpeending what engine type you have, ASZ or BLT.
Mine is a Blt is that the problem one ?
It means it's more difficult to get the engine management light to go out, but fitting and that is the same
Matt
IIRC the BLT engine has the ASV (anti shudder valve) seperate from the EGR valve whereas the ASZ engine has it incorporated into the EGR, so you can remove the EGR valve on the BLT engine without loosing the ASV which seems to be the major drawback on doing the EGR delete on an ASZ engine, however I think doing the EGR delete in either case can bring up the CEL light which you would need to get mapped out
Thanks fr all your help and quick response will wait for the remap at regal autosport before fitting it get it all done at once
Thanks again
Olly
Thanks again
Olly
Happy to help mate :)
Unplug EGR vacuum hose from top of EGR valve. Plug hose with golf tee, job done and 10p out of your pocket rather than that over priced Allard carp. Live with CEL light, or have it mapped out.
You will get slightly less MPG, and cruise engine temps will be higher,, with possible earlier than usual valve seat damage.
Alternatively, do the Elephant Hose PCV mod, and retain the EGR. This stops the crankcase oil vapor from creating the sticky mess inside the EGR.
