How To Get Rid Of.......
I want to take the rear Octavia badge off the Hatch, i know i need to heat it with a hair dryer to warm the glue and the use some cotten to slid behind the letters to lift them,
Now what do i use to clean the paintwork of any glue left behind, after the letters are off?
Thanks,
I used Autoglym Tar & Glue Remover when i done mine.
Applied a good amount via a cloth, left it for 5 mins, then went back to it with another cloth, and it came away fine.
Then gave the area a quick polish/wax to protect it.
:thumbup:
If you have some AS Tardis then use that, if not then you can use White Spirit, just ensure it's not on the paintwork for hours........ :thumbup:
you dont need a hairdryer
just some dental floss. very easy.
I then used some AG Super Resin Polish.
There are lots of alternatives:
1 part nail remover to 2 parts water
kerosene
white spirit
WD40
Ok thanks for the advice, will give it a go at the weekend if the weather is fine.
Yep, as said. I used Tardis on my most recent badge removal.
I use some decent weight fishing rod line myself, which acts as the 'saw' through the adhesive. I've never found the need for any heat.
With previous removals, before I got any Tardis, I used WD40 to tidy up the remains.
I usually do it as part of a full detail, as you'll need to protect the paint after using anything petroleum based anyway. And then it's also easier to use a orbital polisher on the bootlid afterwards, with no badge in the way :thumbup:
Almost identical to what I do, although I do use a hairdryer (whatever good it did). It does make polishing, waxing etc that much less fiddly when you remove the badge :)
Well got round to doing the deed,
Being a total fishing novice, i got a few strange looks asking for some fishing line that was stong enough to take car badges off :rofl:
The badges came off really easy with the line "cutting" through the sticky pads.
With the badges off i was left with lots of "sticky" on the bodywork, so with a large amount of elbow grease an a splash of wd40 every few minutes, i then spent a nice couple of hours cleaning the paintwork.
After that i gave it a good 2 coats of polish and one of selant, it looked nice and clean, i then gave my spolier a couple of coats aswell as it recently been repainted, due to a couple of defects that were there when i bought it. ( done foc by my dealer )
It was only when i got the polish out of my free AG pack that i saw the Tar Remover :dull:
Forgot i had it, might have saved some time!!!
Will try and get a pick up soon.
