Help with retro fitting cruise control
I have bought the cruise control stalk cheap but need the wiring.
I beleive for the VRS (1.8T) there are 2 looms.
Can anyine point me in the right direction for these looms
hope to have a go at fitting this in the next few weeks
much appreciated.
When I fitted mine it came with just one loom that connected to the new stalk then routed across and up out through a 10mm hole in the bulkhead connections cover then straight to the ecu plug where you just put in the extra terminals.
The two looms are if you dont buy from a main dealer, one loom goes from the stalk to bulkhead (footwell side)connector, then the second loom plugs in the other half of the bulkhead connector and then to the ecu.
I think the loom part number was 1J0971425A but best check with the fareham dealer or TPS Hilsea (near JKM).
I still have my installation paperwork if you want it im Only down in Cosham.
Bazaa
Edited by bazaa
