Number plate bulbs
Was following a BMW X5 yesterday and noticed the No. plate bulbs were almost xenon looking..
Anyone know what bulbs I would need for my vRS octy to achieve this look???
I quite liked it.
I'm not sure if these are available yet for the FL? IIRC Superskoda hadn't got them anyway-I don't know what the difference is TBH.
I quite liked it.
If you go ahead and get yourself some of these could you stick a before and after picture up please, would be interested what this looks like :)
Make sure that the bulbs are 38mm if you buy 36mm ones they will be too short.
Should acheive a look similar to mine!
Fitted with 3 SMD LED's
36mm is fine! Remember thats the overall length of the bulb, The contacts are narrower, 38/39mm puts too much strain on the contacts.
You can also gently tease the contacts inwards if there's a bit of play in the fitment!
Edited by Mike B
BMW (and Lexus) have been fitting these for a few years now. I tried a few on the Fabia but never found a set that lasted a decent length of time. Luck of the draw I suppose...
As Mike says, I've never tried a set on the Octy because of the CANBUS system. Didn't seem worth it.
Would be interested in what BMW and Lexus fit as OEM though, if anyone has access to a suitable vehicle! Curious to see if they employ similar LED festoons, or if the entire number plate light assembly is different.
Steve
I have the Superskoda ones on my pre FL for six months now with no issues. I do think the FL is different somehow, as the following is in the description:
*** WARNING LIGHT WILL BE LIGHTNING IF BEING INSTALLED ON THE FACELIFT (09-12) VERSION !!! ***
Discussion to item: Octavia II 04-08 - MEGA POWER LED bulb set for licence plate light
Datum: 13.08.2010 17:34:05; Od: Anonym
Titulek: Available for Facelift model?
Will SMD lights like these be made available for the facelift Octavia II?
odpovědět
Datum: 13.08.2010 17:35:57; Od:
KOPACEK IMPORT
Titulek: Re: Available for Facelift model?
we are working on that..
superskoda.com
Fitted ones i had in my BMW when i picked u the Vrs the same day dealer was like "wtf are you doing" :giggle:
oh yeh got them from www.xenonwhite.de had them in the car and van over 3 years now not a single problem and i run with my lights on all the time in the van.
Highly recommended.
Did they fit those xenon-type bulbs as std to your previous 5 Grizzle? Just wondering if you're the one who can tell me what they use :)
3yrs for your ones does sound like decent longevity though. Do like how they look, but get some more pics once it gets dark :thumbup:
they use something like this but not as many LEDS
These are the van ones at night
Cheers for that. Only thing I don't like with that type is they look pretty bright, a bit too bright for just illuminating the plate maybe? And that they tend to illuminate the bumper, and the ground as well...
