Coilies Have Arrived
Well I bought some budget JOM coilies was between these and FK's but DPM told me these were slightly better.
So unboxing them they look pretty decent just a few questions for when I fit them
Which is the bit I can remove for extra lows? What's the blue bit on the top of the inside two (can't figure how that attachs) the middle to are back and the ones either side are fronts correct??
Is it one of these that I remove for lows??
Zoomed in pic of the blue bit
Sorry for the noob questions
Edited by Tas
yes middles are the rear shocks and springs....
the threaded part completely threads off... so remove this for extra lows (this is called the rear adjuster)
the part you are left with (with the bolt in the bottom) is called the cup....
this bolts onto where the oem spring sits at the bottom on the rear beam....
then all that happens is the shorter rear spring sits on it so it doesnt pop out over bumps etc... should get you pretty low
Edited by BigJase88
Still a little confused so the rears Can I alter the height? Were does the c spanner twist on these? Sorry for noobness there's just totally different to the coils I had on my zr
And about this blue thing
yes you can adjust the height on the rear, but you said you wanted low's so you have to remove the rear adjuster....
that threaded part (the two blue bits threaded together) defines the height the coliovers will be on the rear...
remove the threaded part completely and that will be as low as it can go on the rear
Oh I seeeeeeeeee. Cheers jase.
paint pro B)
It all becomes pretty clear when you come round to fitting and you compare it with what's on the car already :thumbup:
paint pro B)
haha does the job though!
paint pro B)
:thumbup::rofl: Love it
Stick a review up when they are fitted and run in, people are forever asking about various coilovers
Matt
You sir are a superstar
Awesome! Give that man a MS Paint medal the size of a dustbin lid!
Will you need shortened droplinks with these?
Mate fit them the adjust the heights lol
No real easy way to set it up off the car, wind the rears all the way down and fronts half way then fit and let it settle. Adjsut after a week or so.
Cheers for the heads up mate.
No probs, although I adjusted mine after a day as I wound them down too low on the fronts :giggle:
Just a heads up my eibachs springs now have a for sale thread.
