Multiple warning lights on
Yikes! Driving last night and car cut out at traffic lights, wouldn't restart and was showing glow plug light, oil pressure low, traction control and emissions light on. It's showing P0726 as a fault code. Anybody come across this problem before with the 1.9TDi? An AA man reset an airbag light a few weeks back, would this have done anything to the ECU?
Have a look on the link http://www.dtcsearch.com/ and type in the code. It may help you somewhat.
Thanks, This is what comes up
Powertrain - Transmission - ISO/SAE Controlled
Description
Engine Speed Input Circuit Range/Performance
Sorry can't help you anymore than that. This is where the more knowlegable members come in.
Have a look here
Looks like you need someone with VCDS to see what is actually faulty.
Could be a crank sensor.
The other two options sound a bit expensive!!
Have a look here
Cheers Andy, it'll be a main dealer tomorrow either way. Open wallet surgery on the way me thinks.
