Had some VCDS changes done this morning!
Let me know how you get on please, my SM arrives next week and I am going to DIY fit the tow bar etc and I will need the thing coding--I wouldn't mind some of the extras as well!
How will you know how to do it, yetiscot? Or will it be trial and error?
Chris
  • Replies 158
  • Views 41.4k
  • My thanks to Domhnall, a true Gent, for VCDS changes made today: Fogs instead of Xenons for Leaving / Coming Home Large MPH Display in Maxidot Staging (needle sweep upon ignition on) Seatbelt warn
  • I do everything possible to safeguard what I am about to change ..... just in case. (Fortunately I have never needed to revert back to the original coding on someone else's car, as if in doubt I alwa
  • I changed it on my brand new Monte Carlo the other week too. Took a bit of figuring out to get the display sorted by going through the maxidot menus but got it working: In MaxiDot: Units "C
Loving the needle sweep, i would love that on my new Octavia. This may be a stupid question but can Skoda tell the changes have been done and does it effect the warranty?
Some of the coding changes can be seen pretty easily as things will be activated, however anything that the dealer can code could of been done by any dealer.
If you screw something up with the coding and are unable to put it right then don't expect the warranty to cover it, anything else will be fine.
Which is why I'm happy for you to work on my car Martin. You do a test first and copy the file, then do the changes and again copy the file both of which you gave to me. So I have total confidence in what you're doing won't mess things up big time. So if at all possible only let your car be touched by an experienced VCDS operator. For ease of mind.
As to dealer noticing: if they don't notice the needle sweep they must be blind!!! :giggle:
(Fortunately I have never needed to revert back to the original coding on someone else's car, as if in doubt I always try to change things on my own car 1st)
This is IMO the most important bit, it's catch 22 I know but anyone can own a VCDS cable, whereas not every owner will understand and know what they are doing.
"This is IMO the most important bit, it's catch 22 I know but anyone can own a VCDS cable, whereas not every owner will understand and know what they are doing. "
That's exactly why I haven't bought one! :giggle:
Trying to change the dash display on a 12 plate Yeti, keeps saying any changes I make to anything are out of range, error 31 iirc. Even putting the standard code back in flags it up. There isn't a login required is there?
  • 1 year later...
Any toughts how I could set front turn signals as markinglights?
Its 2.0tdi 4x4 Adventure if that matters.
Any one in North East England who is able to do a diagnostic on Octavia 03?
Apologies, just realized this is in the Yeti forum :giggle:
You need the vcds forum :-)
Sent from my Nexus 7 using Tapatalk
cheers :blush:
No apologies needed - you're welcome to drop in anytime!  We don't bite (well, most of us) :x
Thanks Brijo  B)
  • 1 year later...
you'll not get much of a response in here since the number of VCDS owners who happen to have a yeti and look in here will be quite small, the number who happen to be in Newcastle will be smaller still :giggle:
If you are ever in the Edinburgh area I'm happy to help otherwise you might find someone in the VCDS forum :thumbup:
Hi domhnall - are you still in Edinburgh area and able to help with VCDS?
Green2
You might be better using the PM system
Unfortunately Green2 will not be able to use the PM facility as yet.
Hi, Green2, sorry I've not been on much after a telling off from the mods. Still in the Edinburgh area and happy to help
Edited by domhnall
  • 1 year later...
Is there anyone in (near) Edinburgh who would be willing to do some VCDS magic in return for some beer money?
Domhnhall - you still about?
Edited by mattlittle
Hi - just come back to this thread. I sent a PM but it doesn't look like it got through.
Can you PM me or is there a better way to contact you?
Can't spell
I read on another thread that it is no longer possible to set the car region to Australia which is required to get the large MPH in the maxidot. Is that correct and, if so, is there another way to achieve the same outcome?
Did it on mine last month - worked a treat once I found the helpful post that explained how to go on from having got the setting changed to Australia.
So you were able to change to Australia on a new Yeti and then go through setting the correct settings for mpg, etc?
