Had some VCDS changes done this morning!
12 minutes ago, mattlittle said:
So you were able to change to Australia on a new Yeti and then go through setting the correct settings for mpg, etc?
I changed it on my brand new Monte Carlo the other week too. Took a bit of figuring out to get the display sorted by going through the maxidot menus but got it working:
In MaxiDot:
Units
Consu/distance"
Change to mpg (GB), mi (as it defaults to 1/100km, km),
"MFD data"
Tick box for Digit.speed
"ALT.speed dis."
Untick box (this will remove the KPH speed  and replace it with the outside temp display)
  • Replies 158
  • Views 42.4k
  • My thanks to Domhnall, a true Gent, for VCDS changes made today: Fogs instead of Xenons for Leaving / Coming Home Large MPH Display in Maxidot Staging (needle sweep upon ignition on) Seatbelt warn
  • I do everything possible to safeguard what I am about to change ..... just in case. (Fortunately I have never needed to revert back to the original coding on someone else's car, as if in doubt I alwa
  • I changed it on my brand new Monte Carlo the other week too. Took a bit of figuring out to get the display sorted by going through the maxidot menus but got it working: In MaxiDot: Units "C
Yup, my Yeti ordered in September and took delivery at the end of November 2016 and had the setting changed last month when I had front parking sensors fitted.  The guy who did the sensors didn't know how to do the large mph display, but he set the car as Australia on his VCDS, and I sorted it out when I got home.
Cheers. Trying to get someone with VCDS to give me a hand and I'll give it a go.
  • 4 months later...
Has anyone managed to get the comfort lane change blinks from 3 to 5 on a MY16 Yeti?  Changes are taken but it stays as 3 flashes, even if I factory reset the lighting menu on the MFD.
Same occurs for front tear wipe.
as I recall you need to reset the whole system to factory default for it to be taken, a bit ball aching but it worked for me!  -  don't know about tear wipe but surely that's controlled by the slide switch on a steering column stalk
Edited by Frenchtone
Auto park wipers is good, turn engine off and wipers always park properly. Tear drop is not controlled by the slide switch. It's an extra wipe about 3 or 4 seconds after a screen wash.
I changed from 3 to 4 using Carista.  Had to factory reset the whole MFD, but it worked thereafter.
Yeah I did that on mine before I bought VCDS. I'll ask him to do a full reset of the MFD, see if it helps.
You can do it on the mfd system, one page , at the bottom end of the list  gives you the option of factory default reset
