octy vrs 2002 rear brake calipers
does anybody have the part number for a pair of rear brake calipers for octy vrs 2002 also handbrake cable after just replacing front springs and shocks and checking the rear which was suspected wheel baering it appears that i now need two new rear calipers and a handbrake cable :(
1U0 - 615 - 423......... Brake Caliper Housing Left (Minz Green)
1U0 - 615 - 424......... Brake Caliper Housing Right (Minz Green)
1J0 - 609 - 721 AP.... Hand Brake Cable (1698 mm long, same part number for both sides)
Peter
Or, you could buy two recon calipers from here: http://www.vwspares.co.uk/product_info.php?products_id=1903
And some green Hammerite from here: http://cgi.ebay.co.uk/HAMMERITE-METAL-PAINT-SMOOTH-GREEN-2-5LTR-/220741347192?pt=UK_DIY_Material_Paint_Varnish_MJ&hash=item336535a778
and save yourself a fortune.
I did this, and the paint is a perfect match!!
Skoda will charge you about £160 per caliper, this way will cost you less than half.
Also, you'll be able to recondition your old calipers with a recon kit, and have two spares, or flog on ebay. :rofl:
Edited by SP-1
I have a second hand one passeger side absulute nothing wrong with it came off a car I am breaking,only 1 though other has gone...pm me for price cheers
Sure they don't just need a good clean?
  • 10 months later...
During my last service, I was told I needed new rear callipers so I went your recommendation of the TRW from AVS (BHN282 & BHN281) for my vrs auq estate. Fitted fine but now I notice that the brake pedal seems really soft! I asked about air in the lines but was assured that they were bled.
Perhaps the master cylinder is leaking but it was fine before they were changed? I also think that the pad seems to be braking on a smaller section of the disc, i.e. less contact than before.
Any ideas? PS I never painted them but will do at a later stage - I just wanted them to fit correctly before I turned them green.
I still have the oe vrs callipers but they would need to be reconditioned.
