9472881/9472882 - Motor for Fresh Air / Recirculated Air Flap - B108B - Actuator Stuck
During an AutoScan, I found the following fault:
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 AK HW: 3T0 907 044 AK
Component: Climatronic H14 0302
Revision: 00004001
Coding: 0000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_Climatronic A01001
ROD: EV_Climatronic_SK35.rod
VCID: 7BDB258F4125
1 Fault Found:
9472881 - Motor for Fresh Air / Recirculated Air Flap
B108B 71 [009] - Actuator stuck
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 81
Reset counter: 243
Mileage: 16176 km
Date: 2017.14.03
Time: 13:29:39
I tried to erase the fault code but it came back.
I then performed Basic Settings selecting only "Adjust flap end stops"; it "Finished correctly".
Since then, two faults appear:
Address 08: Auto HVAC Labels: 5K0-907-044.CLB
Control Module Part Number: 3T0 907 044 AK HW: 3T0 907 044 AK
Component and/or Version: Climatronic H14 0302
Software Coding: 0000000000
Work Shop Code: WSC 31414 790 00001
ASAM Dataset: EV_Climatronic A01001 (SK35)
VCID: 7BDB258F4125
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 243
Mileage: 16415 km
Date: 2019.14.02
Time: 15:06:49
B108B 72 [009] - Actuator stuck open
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 16415 km
Date: 2019.14.02
Time: 15:06:25
They both re-appear every time I clear them.
No modifications have been made on the car and the Climatronic seems to work fine.
I tried searching Ross-Teck Wiki for 9472881/9472882/B108B but I didn't find anything.
Any suggestions on how to get rid of these two faults?
Thanks in advance.
Complete AutoScan (when I initially discovered the fault):
VCDS Version: Beta 11.2.0
Data version: 20110305
Sunday,13,March,2011,14:56:52:48106
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBBJ21Z1AC(six digits removed)
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CAX) Labels: 03C-906-016-CAX.clb
Part No SW: 03C 906 016 D HW: 03C 906 016 C
Component: MED17.5.5 3981
Revision: LCH02--- Serial number:
Coding: 0000072
VCID: 206132E38803
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.lbl
Part No SW: 1K0 907 379 AQ HW: 1K0 907 379 AQ
Component: MABS MK70M 0105
Revision: 00H32001
Coding: 0016641
VCID: 8127D767A3C9
Revision: 00004001
Coding: 0000000000
VCID: 7BDB258F4125
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 81
Reset counter: 243
Mileage: 16176 km
Date: 2017.14.03
Time: 13:29:39
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 D HW: 1K0 937 087 D
Component: BCM PQ35 H 103 0537
Revision: 00103 AB
Coding: 46180AB8B80508C000080001150081EC034100AE400089605C0440000000
VCID: 3245C8ABD6EF
Subsystem 1 - Part No: 1Z1 955 119 C
Component: Wischer 11050 22 0601
Coding: 00D7B7
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q2 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2DHEAJ
Coding: 0020786
VCID: 3D5FEB971FB1
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CE HW: 1K0 953 549 CE
Component: J0527 055 0111
Coding: 0000501
VCID: 77D339BF7D0D
Subsystem 1 - Part No: 3T0 959 537
Component: E221__MFL-URO H07 0011
Coding: 00000128
Shop #: WSC 00000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1Z0 920 843 B HW: 1Z0 920 843 B
Component: KOMBI H21 0109
Serial number: 00000000000000
Coding: 110B00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 3753F9BF3D8D
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H16 0222
Revision: H16 Serial number: 4020K095080620
Coding: E9807F06000202001302
VCID: 66ED64FB2AA7
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H21 0109
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
VCID: 3753F9BF3D8D
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 AA HW: 1T0 959 701 AA
Component: Tuer-SG 009 2107
Coding: 0004342
VCID: 76CD34BB7A07
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 68 2901
Revision: 00H15000
VCID: 2F43C1DFC5DD
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
Coding: 0004342
VCID: 48B18A434073
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1Z0 035 161 F HW: 1Z0 035 161 F
Component: SWING 008 0062
Revision: 0H001001 Serial number: SKZ1Z2I8242386
Coding: 050004000001
VCID: 3147C7A7D3E9
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 31414 790 1012545
VCID: 3245C8ABD6EF
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 334BCDAF29F5
End ---------------------------------------------------------------------
Revision: 00004001
Coding: 0000000000
VCID: 7BDB258F4125
1 Fault Found:
That looks like the motor is actually stuck, or the flap door has an obstruction of some sort. Since this is the Recirc. Flap I'm guessing it's very near the Air Pollen filter. If that's like the VW equivalent, I think you can remove the pollen filter and gently push the flap door or look at the movement while running Basic Settings. I would not prevent it from moving during the test, but see if it sticks.
Thanks Dana.
Can anyone confirm that, on Skoda Octavia 2 Facelift, by removing the air pollen filter I will actually be able to see the air recirculation flap?
But, you've been given some sound advice - why can't you not just go and use it, then report back, instead of asking questions about the answer given?
  • 7 years later...
There are two flaps.. One for outside air and there is one inside for the AC when you turn on the switch. The one for the AC to be accessed, you need to remove the glove compartment and its just behind that on the top. The one for the outside air can be seen after removing the cabin filter. The error that you have seems to be of the top one.
  • 3 years later...
Re-reviving this old thread since I just found the same fault in my diagnostics.
The top one is the hard-to-access one, the one related to the AC?
Any chance that this is why I my airco isn't (or seems not to be) working?
