suspension what to do
hi currently running eibach springs and koni fsd shocks but just doesnt sit right with my 17's so my question is lower springs or coilovers
but i dont want to ruin the ride to much as the roads around me are not exactly smooth
Edited by lee_vrs
Coilovers. Lower it to whatever Hight you want and will prob ride better than lower springs tbh
Matt
springs really req matched dampers
a matched spring and damper combo will outperform most coilover kits... (unless your talking KW V3's set up properly)
FSDs dont sit right, had them on mine a few years ago - barely looked lower!
I dont think you can get lower springs, all are around 40mm (25 for vrs)
I have Koni Sport now and it sits great front and rear, although the springs seem softer than Eibachs but thats actually equating to a nicer ride, especially over speed bumps and the like.
I didn't think that the springs that dropped the fabia a lot had any shocks available for them, so even with the kit this bloke has, they'll still be shorter than the shock is designed for?
KW V1's verses a Ibiza tdi on shocks and springs (don't know which tbh) and I'd pick the v1's for comfort every day. But that's down to a large amount of personal preference I guess
Matt
  • Sponsor
I'd say go for coilovers.
Damian @ DPM Performance
coilover ride is there a massive difference in ride between the cheap kits ie jom and the likes of ap and weitec
  • Sponsor
The more you spend generally the better quality kit you get in terms of ride and build.
The problem is that the FSd`s can raise slightly , then mix it with Eibach springs , that will lower approx 20 something mm , then that is not a big drop
So if you decide to lower to what YOU want , then maybe worth going for coilovers
Good one , not a cheapo one
That will give a bit of decent ride quality
But you will not get ride quality as good as what you have now with the FSD`s and Eibach
Shop around too , dont just go for what a few people rave for
JOM......nah
Sarah
