Radio/CD player
I've blown the radio fuse and was wondering how to go about replacing it. Thanks for any help.
Open drivers door fully. Side of dash there is a panel that prises off (use the blade of the ignition key). Fuse puller tool is inside, as is the fuse box.
Forget what number fuse it is, but it's listed in the handbook.
No. 45 I thinks. It's one of the bigger size fuses, right hand side near the bottom. Think it's 20 amp. Yellow.
Edited by Fabla
Thanks Peeps!
I think this is how it should be - unless there's an obvious post for a problem - ask a question and get a sraight, honest, helpful answer.
It's much politer than " go elsewhere - the answer is on here if you look".
Thanks again.
