were can i buy 40mm or 50mm springs
hi am after a set off 40mm lowering springs or more , any one know where can get a set from
You will struggle to lower a (I presume vRS) 50mm with just springs. Consider coilovers IMO.
yeah was thinking just 40mm springs. did not really want to go down the road off coilovers
Why?
Matt
I presume due to the cost, i was wondering if there are any springs over the 30mm mark..
you could always cut a few coils off the spring to make it lower
onslaughtttt!!
Try DPM, I bought some supersport 55mm lowering springs from them
onslaughtttt!!
Then try and get through an MOT :giggle:
Cheeky hidden message there luke!
This topic has been discussed many a time, if you are looking for some serious drop then ideally you want to be looking at Coilovers as your std dampers are not designed to be run that low, will drasticly reduce life of them.
Give Damian from DPM a PM he is really helpfull! :thumbup:
I also bought these and they are fantastic, lowered the car much more than I would have expected, sit nicely in the arches and not much gap on standard alloys :)
Think spax do 50mm springs
post a picture off how the car sits bud
iv got some 40mm spax springs if you want them, not done many miles
the springs i bought were listed for a fabia but im not sure about the drop on a vrs. apparently the vrs already has lower springs than a normal fabia so im unsure if the drop is 40mm from standard fabia height or vrs if you get what i mean.
This is how it sat on the 40mm springs
Edited by E11HES
Spax 50mm Springs
  • Sponsor
Thanks guys!
If I can be any help just let me know :thumbup:
Damian @ DPM Performance
