Is my map iffy?
Following on from my comment HERE Post #11 about remaps.
I was wondering if the techy types out there could have a look at my
RR chart and give me any idea if the map my car is running "seems" okay.
I'm not really certain what I should be looking for regarding the chart.
Sure, I can read it and understand the overall result but any more than that
and I'm floundering a bit. If it looks like a dodgy effort then I'd probably
be looking to re-re-map it somewhere reputable, and have a custom map done
maybe reducing the torque a bit. I still weep when I think of the £600 I had
put aside for lowering the car having to be spent on the clutch/flywheel. :'(
I had Unit 18 in mind for the new map if necessary.
Currently it drives okay,but I haven't really spanked it since it ate a clutch
and flywheel. I'm worried that its been wound up too much and thats what caused the failure.
I can drive it smoothly but then again, I'm used to it now.
I found it a bit of an animal at first if I'm honest.
Any questions please ask,
Heres the chart.
map dont look too bad, peak torque is 2700 which is the norm for standard 130turbo, torque is below 300llb/ft, usually above 300 you run into trouble with standard clutch, just dont boot it under 2000rpm and the new clutch should be fine, map looks fine, dont worry about it, as long as it drive alright too
Looks like a standard remapped fabia graph to me Garry :thumbup:
Looks just fine to me, My map is from unit 18 (Richard Washbrook) and this is the results. Rolling Roaded at AMD essex too.
Have you got the right map?
You might have a map for a different county
Personally i really on my sat nav
Try one from the West Midlands ;)
Gerrr stick a thread up with some pictures, I'm sure someone will be able to give you an idea what it's like. Plenty will talk bollacks but a few will give some good input!
Matt
It's almost like you could see into the future Matt.
Thanks for your help. :dull:
lighten up was only having a bubble :thumbup:
