Electric window problem
Just replaced the battery in my Fabia, everything seems to be working fine except for the switches for the electric windows. The automatic up/down isn't working so I have to hold the switch for the duration of opening/closing. Anyone know how to fix this?
Cheers, Mike
Doing what you are doing, by holding the window switch down and then up a few times should reset the one-touch window facility, on the drivers side.
I did on mine, plus resetting radio code when I removed battery to check power-steering annual oil-level check.
hold both the buttons on the drivers side for 5 seconds in the up position whilst the windows are up.
Open window, close window and hold switch in close position for 10 seconds.
This will reset the one touch function.
Perfect, all working now, cheers guys! :)
