Reversing Camera ?
Help !
Hs anyone fitted a reversing camera to their Octy ? I have seen a nice compact looking item on ebay which replaces one of the number plate lights.
I have a Columbus Sat Nav and, after reading the book. it looks like, in some options it can show T.V. My theory is that therefore there could be an input I could use for the camera.
Any comments or ideas gratefully received !
:thumbup:
Yes it will support reversing camera ....
U might need to update your parking sensor controller and will need coding via vcds.!
HTH
This is only if you want the camera to work alongwith the parking sensors ..!
Edited by pz1811
Hi
I know its not an octavia, but I fitted a mk6 golf camera to my golf mk5. I made the loom for the taigate. If you use the camera that is used on the golf estate that should fit your octavia. In terms of wiring you only need a feed from reverse light and a permanent live from the fusebox and the coax video cable that runs to the columbus
sorry to hijack the thread, but im thinking fitting a camera too, a wireless one, are these any good ?
