Brake Judder ?
I have a 04 fabia vrs , i have the 312mm brake set up .
I have slight slight brake judder , this is the second lot of pads
and discs , anyone got any ideas ?
Could it be just bad luck and there **** discs again !
or could it be something else ?
You need a dial gauge to check disc run out (should be 4 thou or less). Also check wheel bearing and suspension bushes.
defo check the front suspension bushes
