Engine Faulty Codes
Anyone could tell me how to read the engine faulty codes? I have a
yes you need a 1552 diagnostics machine to read complete with flash code harness. what is the problem i maybee able to help, by the way is this a monomontronic engine you have because we didn't have these over here until 1993.
Mono.....what? :rolleyes:
monomontronic (single point injection to you nick)
I thought MPI was the fancier sort?
mpi's didn't come out till 96 for the 1.6 and 97 for the 1.3
If you fail to get hold of a 1552 machine, why not download the VAG-COM software (its free to download for diagnostics) make up, or buy, a suitable harness, link it to a PC / laptop and read your own codes.
When plugged in it will give you the same numeric codes as the dealer gets from his 1552 only it adds a plain english explanation of the problem, without having to go away and look up the code.
This is not a monotronic injection. Pierburg 2EE is a electronic carburettor driven by a ECU.
I know that is a easy way to read the codes using a LED, I saw some specification from VW equipped with 2EE Pierburg. I don
what is the problem florin ?
  • 3 years later...
Salut !!Ai cumva un manual pt Skoda favorit??Tocmai mi-am luat o Skoda Favorit 135 Le si as dori sa fac unele verificari/reparatii la ea.Stii de unde pot lua un kit de reparatie pt carburator,si ce contine acesta??Mrs.
  • 4 years later...
