service...
I have been looking back through my service history and there is nothing really recorded in the book from when i bought the car and when i bought the car the garage said they would service it so this makes me unsure of what has actually been carried.... if any thing
i am thinking about doing one big service next month so tha i know for peace of mind sake its done, what would people recommend i change.....
What is the age and milage of the car??? and the engine type?? B)
1.9, 58k and she is on a 55 plate :yes:
Every year or 10,000miles replace oil, oil filter, drain water out of fuel filter
Every 2years replace brake fluid and pollen filter
Every 40,000miles or evey 4years replace air filter, fuel filter,
Every 80,000miles or 4years replace timing belts, tensioners, aux' belt
Every 5years replace engine coolant
Every 2nd timing belt change I replace all the ideler pulleys and water pump, some people do this every change.
This should give you a starting point! B)
I'd replace the belt at 60k as recomended in the service manual.
Haynes say VAG say 60k miles for engines with unit injectors (without injection pump) and 80k miles for engines without unit injectors (with injection pump). B)
Engine codes AMF,ASZ,ATD have unit injectors so 60k miles!, but i'd still do every 4yrs!! B)
Edited by fabdavrav
i have done the timing belt and ideler pulleys and water pump recently so that i can tick off the list, if i do the oil filter, oil, pollen filter and fuel filter things should be good. ALthough i dont think the brake fluid has been changed :S
