u280 fault code
I got a U280 scanner today and it produced an engine fault code which isn't listed.
It is: DTC 04 00557 01/04
The car is: 1.6 8-valve petrol Octavia 1 (AKL engine)
Anyone have any idea? I have a problem with the engine temperature gauge, it works sometimes but erratic other times. Also intermitent engine hesitation and occasional rough running at tickover or when accelerating
You'll have a dodgy coolant temp sensor, which causes loads of engine problems. Very common problem on all VAG engines. Buy a genuine VAG CTS & that should sort the engine prob out.
DTC 00557 is a power steering pressure switch fault code.
