Rear fog lights/s
Silly question maybe but...
Does the Fabia VRs have 1 or 2 rear fog lights?
I am sure it had 2 working on mine, then a break light bulb went and I noticed that only 1 works, although both sides have the available bulb etc
Keith
It has one rear fog light as standard, but I believe you can get both working if you get it enabled with vag com and put the correct dual filament bulb in.
You can't enable the second fog with VCDS, You need to wire it off the O/S cluster!
I have 2 as standard
Iv only got one, but as said, bit of wiring and both can work
