fault code
plugged vag reader into car today and came up with
19586 p3130 035
anyone know what that is??
i did a quick search for error codes but couldnt find anything.
cheers dano
Does the supplier of the scanner not give any support or fault code help?
Where have you searched?
P3130 = EGR Regulation Exceeded.
In a nutshell this code means that not enough exhaust is flowing into the intake through the EGR valve and this could be caused by several things. I would check for leaks or a bad EGR valve diaphragm.
egr had bin blocked and sealed off when new hybrid turbo got fitted,
Then you need EGR Delete incorporated into your mapping :)
