blue wire next to gearbox?
what is this blue wire next to the gearbox that i keep hearing about that causes electrical problems??
Alternator sense wire. If broken or corroded no battery charging below 2,000 RPM
could this cause electrical problems, eg when i use my steering on full lock or just in general sometimes, i get free beeps and it sometimes when i restart the car has problems turning on?
and a night cause flickering lights in my dash
Maybe, do you have a battery light with ignition?
Mines has been broken since i got it and doesnt cause any running issues
Maybe as i have a petrol it revs over 2k 90% of the time anyway
Your car doesn't have electric power steering.
The light in the dash can be dead and the signal to the alternator can still be OK. The alternator is no longer fed by a bulb in series with B+.
Saturday,04,June,2011,11:54:26:38917
VCDS Version: Release 10.6.4
Data version: 20110418
Chassis Type: 6X - VW Lupo
Scan: 01 02 03 08 15 17 19 25 35 37 44 45 55 56
VIN: WVWZZZ6EZ2W007817   Mileage: 160480km/99717miles
Address 01: Engine        Labels: None
  Part No: 036 997 033 E
  Component: 1,6l/4V SIMOS3  00HS7000
  Coding: 00031
  Shop #: WSC 00032
  VCID: 1D3A0813BD21
  WVWZZZ6EZ2W007817     VWZ1Z0B2014418
8 Faults Found:
17911 - Load Signal from Alternator Term. DF: Implausible Signal
           P1503 - 35-10 -  -  - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
           P1602 - 35-10 -  -  - Intermittent
17751 - Ignition Coil Power Output Stage 2: Shorted to Ground
           P1343 - 35-10 -  -  - Intermittent
16687 - Cylinder 3: Misfire Detected
           P0303 - 35-10 -  -  - Intermittent
16686 - Cylinder 2: Misfire Detected
           P0302 - 35-10 -  -  - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
           P0300 - 35-10 -  -  - Intermittent
17953 - Throttle Valve Controller: Malfunction
           P1545 - 35-10 -  -  - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 6X0-907-379.lbl
  Part No: 6X0 907 379 C
  Component: ABS/EDS 30 IE CAN  V004
  Coding: 15603
  Shop #: WSC 01233
  VCID: 448C9D777E0B
No fault code found.
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
  Part No: 1C0 909 605 A
  Component: 2T AIRBAG VW51        02
  Coding: 12884
  Shop #: WSC 01233
  VCID: 22403BEF845F
1 Fault Found:
00532 - Supply Voltage B+
           07-10 - Signal too Low - Intermittent
Address 17: Instruments        Labels: 6X0-920-xxx-17.lbl
  Part No: 6E0 920 900
  Component: KOMBIINSTRUMENT BOO V10
  Coding: 00440
  Shop #: WSC 00032
  VCID: DFC6F21B77AD
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
  Part No: 6N0 909 901
  Component: Gateway K<->CAN
  Coding: 00022
  Shop #: WSC 01233
  VCID: F0E481A79A33
Address 25: Immobilizer        Labels: 6X0-953-257.lbl
  Part No: 6X0 953 257
  Component: IMMO                0008
  Coding: 00001
  Shop #: WSC 00000
  VCID: FDFAA893DD61
Address 35: Centr. Locks        Labels: 1C0-962-258-III.lbl
  Part No: 1C0 962 258 AB
  Component: 16 Zentr.Verriegel. 0003
  Coding: 00017
  Shop #: WSC 01233
  VCID: 67D66AFB2FFD
Address 45: Inter. Monitor        Labels: Redir Fail!
  Part No: 6N0 951 171 D
  Component: Innenraumueberw.    0003
  VCID: 3064C1A7DAB3
Address 55: Xenon Range        Labels: None
  Part No: 6N0 907 503
  Component: Leuchtweiteregelung 0003
  Coding: 00001
  Shop #: WSC 00000
  VCID: ECDC95D7B61B
Address 56: Radio        Labels: 1J0-035-18x-56.lbl
  Part No: 6N0 035 186 B
  Component:  Radio BNO         0006
  Coding: 00403
  Shop #: WSC 01233
  VCID: 2D5AD8D3CD81
1 Fault Found:
00856 - Radio Antenna
           36-00 - Open Circuit
End   ---------------------------------------------------------------------
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 15: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 25: DTCs cleared
Address 35: DTCs cleared
Address 45: DTCs cleared
Address 55: DTCs cleared
Address 56: DTCs cleared
  Coding: 00031
  Shop #: WSC 00032
  VCID: 1D3A0813BD21
Readiness: 1110 0101
  Coding: 15603
  Shop #: WSC 01233
  VCID: 448C9D777E0B
  Coding: 12884
  Shop #: WSC 01233
  VCID: 22403BEF845F
  Coding: 00440
  Shop #: WSC 00032
  VCID: DFC6F21B77AD
  Coding: 00022
  Shop #: WSC 01233
  VCID: F0E481A79A33
  Coding: 00001
  Shop #: WSC 00000
  VCID: FDFAA893DD61
  Coding: 00017
  Shop #: WSC 01233
  VCID: 67D66AFB2FFD
  VCID: 3064C1A7DAB3
  Coding: 00001
  Shop #: WSC 00000
  VCID: ECDC95D7B61B
  Coding: 00403
  Shop #: WSC 01233
  VCID: 2D5AD8D3CD81
Dont worry about all the other faults they have been fixed, its what happens when you use crappy somerfield 95ron
The 17911 fault is likely caused by the other wire (DFM - brown/red) being broken.
Where is this? Doesnt cause any issues?
Next to the blue wire and is the digital field monitor (output) wire to the ECU. The alternator works normally but the ECU sees a fault.
That'll do for me
my battery light is on when i turn my ignition on!! i seemed to have found my fault. so far anyway. My earth on my battery was faulty as now i have found a new earth with a new cable everything seems fine so far fingers crossed
