Boot and grill badge removal
Is the Skoda badge on the front grill part of the grill, or can it be removed? If the latter, how much is a replacement as mine has faded and the plastic peeling off.
The same with the rear, is it just stuck into the circular ressess in the same way the Octavia badge is?
Both replacable easy enough with some heat and fishing line. If I remember correctly there's a screw in the back oc the front one.
If its still in waranty, then your dealer should replace them
Not sure about earlier cars but on the FL front grille the round Skoda badge is held on by two pegs that have been 'melted' into the surround (so need to be drilled out) AND are held on with adhesive pads too.
New badges are around £13-14 from the dealers.
I've seen them only for £8 to £9 (not sure about delivery costs)
